B2910 Cruise Control??
   / B2910 Cruise Control?? #1
dmftoy1
Lexington, IL
Kubota B2910 (Delivery 8/7/03)
Has anyone figured out how to adjust the b2910 cruise control yet? I was out spraying the other day and it would've been very nice to have working again. I'm sure there's some adjustment on it somewhere but I haven't been able to find it. (I did tighten the spring tension but that didn't help)
Have a good one,
Dave
Ok, after reading some other posts on this board I decided to go trouble shoot this problem and it turned out amazingly simple. What is happening (on my machine at least) is that there is a spring that applys tension to my control lever (for the cruise). If you're looking up from the bottom this is a spring that runs parallel to the rear axle and it has a nut and a jam nut on one end and o the other end it connects to a "lever". (not the control lever). On my machine this "lever" had gotten hung up on a molded piece of metal on the side of the frame and so it wasn't putting pressure on the set of rubber pads/plates that make the cruise work. I popped if loose from where it was hung up VOILA the cruise now functions perfectly.
FWIW I think I can now fix it easily without popping off the cover in front of the seat. I think it'll just be a matter of crawling underneath and freeing up the lever if it gets stuck again.
Just to document how it was "failing". THe lever would still cause the pedal to move down, it would just never "hold" in one place.
Have a good one,
Dave
   / B2910 Cruise Control?? #3
Dave,
Glad you got the problem solved.
I think it says a lot for the group here at tbn, that they did not answer your question!
When you don't know you don't speak...why confuse the issue?
I read your post earlier and hoped you would get some help, but since I did not have a clue I stayed where I should have....in quiet land... /forums/images/graemlins/smile.gif
Again, glad you were successful... /forums/images/graemlins/smile.gif
48 PIECE HEAVYEQUIPMENT KEY SETS (A53843)
48 PIECE...
2017 Ford Explorer AWD SUV (A54815)
2017 Ford Explorer...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A53473)
NEW HOLLAND 706 30...
Plasmarc PM150 Plasma Cutter (A51691)
Plasmarc PM150...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
2004 Sterling Acterra Cab and Chassis S/A Truck (A54814)
2004 Sterling...
