B2910 3pt "Valve" goes to Closed while using it
   / B2910 3pt "Valve" goes to Closed while using it #1
dmftoy1
Lexington, IL
Kubota B2910 (Delivery 8/7/03)
B2910 3pt \"Valve\" goes to Closed while using it
Ok, this is probably a really stupid question, but I've noticed while using my brushhog that at times the valve that controls how fast the 3pt "drops" will go to the "Closed" position and I then have to open it prior to being able to lower my brushhog. It always seems to happen when I'm working in some tougher brush and raising/lowering the brushhog. Is there some way to "lock" this valve into a position, or is this some form of safety feature? What am I doing that causes this? /forums/images/graemlins/smile.gif /forums/images/graemlins/smile.gif
Any and all input appreciated.
Regards,
Dave
   / B2910 3pt "Valve" goes to Closed while using it #2
Re: B2910 3pt \"Valve\" goes to Closed while using it
dmftoy1,
I have 230 hours on my b2910 and have not noticed that happening...
Only have a couple hours brush hogging though. But from what I can see, the position of that knob does not change with use or vibration on my tractor. Not that there is much vibration... /forums/images/graemlins/smile.gif
I don't think what your are seeing should happen normally. That knob on my tractor turns freely, but there is a little resistance, and it is not loose by any means. Not tight either, just firm enough to hold itself in place I guess...
Thanks, I was guessing that there was a "lock" of some sort. Mine's not very hard to turn by hand. I'll have the dealer look at it when they mount the FEL next week.
Regards,
Dave
   / B2910 3pt "Valve" goes to Closed while using it #4
dmftoy1
I have 223 hours on my 2910 and it has done that since day one.Mine will even do it when Im mowing with the billy mower after a while.If I have to brush hog for 2 or 3 hours or longer,I may have to turn that knob 3 or 4 times,becuase it will get to where it wont let the three point go down.My knob turns pretty easy also.
   / B2910 3pt "Valve" goes to Closed while using it #5
Mine doesn't do that, it stays put right where I leave it.
Probably a simple fix, but your dealer will know for sure.
   / B2910 3pt "Valve" goes to Closed while using it #6
My new 2910's valve has been acting up from hour one. I have had the same problem you described, with a Gannon box blade hanging on it. In addition, I have had it refuse to lock. In addition, I cannot reduce the lowering speed to the point where the implement descends slowly. As I keep turning the valve clockwise (I never do hit "lock"), the lowering turns into a series of jerks, each way too fast, as I move the position control down. Dealer is looking at it now, but I know he will try to tell me that the implement is too heavy. Have you heard back from your dealer?
I haven't done anything with mine yet as it always works after I open the valve up. I do have the factory service manuals now though so I'll probably take a look at it some Saturday when the in-laws are in town! /forums/images/graemlins/smile.gif
Have a good one,
Dav
2011 Liebherr L586 Wheel Loader (A53473)
2011 Liebherr L586...
2007 Mack 600 Day Cab Winch Truck (A53117)
2007 Mack 600 Day...
Payment Terms (MUST READ) (A50775)
Payment Terms...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
Kalamazoo 8-6-W Metal Cutting Band Saw (A51695)
Kalamazoo 8-6-W...
CAT Skid Steer (A50322)
CAT Skid Steer...
