Thanks for the info. It is leaking around what looks like a blue seal (or O ring). I took the little shroud off that protects it from the elements but I didn't have any time to investigate. I first thought that I would see if the bolt that holds the gear on was loose before I took it off. The link to the kit above doesn't work, but I can check with the local dealer.
