NorthIdaho3200
- Joined
- Oct 7, 2018
- Messages
- 10
- Tractor
- Kubota 3200
During this last snow season, I accidentally ran over a tarp and it tore up a plastic seal that is on the impeller. I finally got the seal. In order to replace it, I need to take off the impeller. The only way to get the impeller off is to remove it from the box of the snow blower. So today, I removed the bolts holding the impeller to the side of the box and the bolts holding the center drive unit to the middle of the box. So right now, the impellers and the drive unit are free within the box and being supported by a floor jack.
I then moved on to the rear of the unit. I removed the main drive gear and chain. I also removed the set screw on the collar that is on the shaft. As indicated by the yellow arrow. I can't seem to get the collar on the shaft off and I can't get the shaft to go towards the front. (using reasonable mallet strikes)
The three bolts that are poking in from front to rear are really loose after I removed the nuts that used to hold the triangular piece that surrounded the shaft.
Can somebody please tell me how to pull everything out to the front? Thanks!
