B2781 blower on BX?
/ B2781 blower on BX? #1
RDG
Ontario
Kubota B7800,BX2660
Hello everyone.
I currently own a B7800 with a B2781 front mount blower.
I've been shopping for a second, smaller tractor for mowing/snow removal.
I've found a nearly new BX1860, but can't find any info whether the blower will fit. I realize the subframe is different, does anyone know if this blower will fit on the BX subframe. Does it have enough power to operate it??
Thanks in advance for your input.
/ B2781 blower on BX? #2
It wont fit. The blower for the bx1860 doesnt even have a sub frame (at least mine doesnt). If you google you can fine a pdf that shows which blowers will fit the 1860
/ B2781 blower on BX? #3
I doubt the B2781 can front mount on the BX1860... but,
it appears Kubota recommends the BX2750 blower for this tractor, and it does require BX2751 Quick Hitch Subframe Kit, BX2314 or BX2324 Front Loader
Valve, and BX2752 Mid PTO Kit.
Pete
I found that pdf showing which blower fit which tractor and the corresponding subframe. By crossing between tractor models and subframe interchangability, I figured it would fit. A quick call to the dealer quashed that theory though. The B2781 uses a larger 4 blade fan for throwing the snow, while the BX's use a smaller 3 blade. Aparently this requires more HP than the BX1860 has.
Tractor shopping just got more expensive.
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
HAMM H12i ROLLER (A65053)
HAMM H12i ROLLER...
2015 New Holland 560 Round Baler  5x6 Bales (A63688)
2015 New Holland...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A61307)
2-Row Peanut...
Excavator trenching bucket- one bucket per lot (A63689)
Excavator...
