B2710 vs B7800
   / B2710 vs B7800 #1
bobby2262
This is my first post here. I'm looking to buy my first tractor and looking in the orange direction after reading all the post here.
My question is, I've found a B2710 w/ 130 hrs. on it with FEL, Tiller, Finishing mower, Post hole digger, scrape and box scrape, All looks new, been garaged.
Price $12,500.00.
But I've been looking at the B7800 w/ FEL and woods BH new with low finance from Kubota. I have 7 acres with about 3 that I need to work, basically clean up after it's already been ground up with one of those Bobcat Mulchers.
My question is that the 2710 looks a little small for FEL work.
Does anyone have any experience with the 2710 vs the B7800. I would thank you for all advise.
Bobby:)
   / B2710 vs B7800 #2
The B2710 is basicly the same tractor that a B7800 is with slightly less horsepower. The frame size is identical. 130 hours is the same as new if it has been cared for. I believe that the same backhoe will fit both, and the Woods BH70, and Kubota BH75 would be the correct choice in either case. The B2710 probably has position control on the three point, and perhaps a nicer three point hitch (was optional) Check both for a mid PTO though I think all B2710's shipped with one. Unless there is something you really don't like about the B2710 I would look pretty closely at buying that.
   / B2710 vs B7800
Thanks, for the info. I just looked at the 2710, looks new and has been taken care of. The FEL,finish mower and Tiller is a Kubota brand, the scrape and box scrape and post hole digger is not Kubota brand and has been out in the weather but still has paint on them. Tires look new also.
I'm going this afternoon to drive it and check it out a little more but it looks like a go right now.
   / B2710 vs B7800 #4
I love my 7800 but that looks like a good deal.
   / B2710 vs B7800 #5
I agree that the 2710 sounds like a good deal. I've seen not-so-clean 2710s selling around these parts for that kind of money with no impliments (just a loader). Chuck is right, they are virtually the same tractor...... the 2710 will give up a few ponies but has a few "deluxe" features. I don't feel you will really miss the 3 hp.
   / B2710 vs B7800 #6
I've not used a B7800, but did own a B2710 and really liked that little tractor. I bought one of the earliest models which had a single hydraulic fluid filter, while the later ones had two such filters; one on each side. I think the second filter is probably a good idea, but I had no real problem with the single one. And I'd prefer the B2710 over the B7800 simply because I like position control that much.
   / B2710 vs B7800
Thanks all for the input. One question since I'm new to tractors, at least the Kubota's. What is the position control? What does it do or not do?
Thanks all!
Bobby
   / B2710 vs B7800 #8
Briefly, position control allows you to set the height of an implement using a scale on the control for reference. You can go back to that same height over, and over. On the B7800, you have to lower the implement to the ground for reference, or eyeball the height of the implement.
   / B2710 vs B7800 #9
Bobby, there are probably others who can explain it better in fewer words, but . . . I used to have a B7100 that did NOT have position control. When you moved the lever forward, the 3-point hitch started down and it continued down until it either reached the lower limits of its travel OR you moved the lever back to the center. By the same token, when you pulled back on the lever, the 3-point started moving up and would continue until it reached the limits of its travel OR you moved the lever back to the center. Then the B2710 did have position control. You never worried about moving the lever to the center. If you pushed the lever forward about half way and left it there, the 3-point would lower to that level and stop. If you pulled back on the lever, the 3-point raised, but you left the lever in the "position" you wanted and the 3-point raised or lowered to that point and stopped and stayed there. So, if you lower an implement, for instance a rotary cutter, to the height you want to work, then later you raise it for some reason, you can quickly and easily lower it again to the same level without even looking at it.
As with many "features", position control is not really necessary, but is a great convenience that I like.
   / B2710 vs B7800
Thanks Chuck and Bird,
I think I understand it now. I've already committed to the 2710 and I think it will do just what I need. I'm very glad that I found this forum, I've learned a lot of things that I didn't know about the Kubota's. I don't think I'll be disappointed. I'll post pic's of it after the deal is done.
Thanks again all!
Bobby
2016 Ford Fusion Hybrid Sedan (A50324)
2016 Ford Fusion...
2002 International 9200i Truck (A52748)
2002 International...
2013 MACK ELITE LEU 633 GARBAGE TRUCK (A51406)
2013 MACK ELITE...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A52748)
2012 JOHN DEERE...
2014 International Durastar 4300 Terex BT3063 63ft 15 Ton Crane Truck (A50323)
2014 International...
Yamaha Vmax Boat Motor (A50121)
Yamaha Vmax Boat...
