Mowing B2710 too big for lawn mowing?
   / B2710 too big for lawn mowing? #11
Hi Mark,
I mow 6 acres with my B2910 (pretty close to what you have) and a 72" mid mount mower. I also have R4 industrial tires that are not filled. As long as the ground isn't too soft, I don't have any problem with leaving tire marks in the ground. Last year I started the mowing season about a week too soon before the ground firmed up enough, and I did leave some ruts. I think the key is to make sure the ground is firm enough before you mow, and also to remember to take it out of 4WD before you make any turns. I have a couple of hills that I need 4WD for, and every once in a while I forget to kick it back into 2WD, and the front tires will scuff the grass off where you make a sharp turn. I also haven't noticed any problem going over our leach field with my tractor either.
Good luck, and welcome to TBN. /forums/images/graemlins/smile.gif
   / B2710 too big for lawn mowing? #12
Like the others have already stated, a lot of it depends on your application but it is probably not too big. My uncle mows his lawn now with a L3130 with loader and loaded R4s and says that it does less damage than his old B8200 did with loaded R1s.
Jeff
   / B2710 too big for lawn mowing? #13
I have a B-7800 with loaded R-4's and a 60" mmm although I haven't gotten to use it to mow with since I bought it in November. I have driven over the drainfield numerous times this winter with the 500 pound box blade on the back and a load in the bucket and it didn't leave any ruts. I did this while the ground wasn't frozen too just to test it. I figureed with the bucket loaded and the box blade on that would be the most weight it would see!!! I can't wait til spring to get started mowing!!!!!
   / B2710 too big for lawn mowing? #15
Don't forget the other things you may want to do with the tractor.
My L3000DT seems a bit big and clumsy mowing, but it sure is good at clearing snow, running a tiller, and box blade.
   / B2710 too big for lawn mowing? #16
it really depends on the lawn u are mowing, how many trees, etc. plus the type of ground. i run r4's on mine and i find that even with dry conditions it will scuff the grass when turning especially if sharp turns are required.
Caterpillar 2PD5000 5,000LB Diesel Forklift (A56857)
Caterpillar...
2013 Freightliner M2 106 Elgin Broom Bear Series H Street Sweeper Truck (A55788)
2013 Freightliner...
6' ROLLOVER BOX BLADE (A58375)
6' ROLLOVER BOX...
2016 John Deere 35G Mini Excavator (A55973)
2016 John Deere...
2018 Dodge Charger Sedan (A56859)
2018 Dodge Charger...
International 424 Loader Tractor (A59814)
International 424...
