b2710-how to adjust heavy HST pedal ?
   / b2710-how to adjust heavy HST pedal ? #1
Anonymous Poster
Epic Contributor
Hi,
I noted on the 'oil & lube' board that there is a known fix for my heavy-unresponsive hydro pedals ? Can someone in the know share the fix with me ? Thanks
DWR
b2710 1.5hrs old....
   / b2710-how to adjust heavy HST pedal ? #2
HST pedal slow to return to neutral
I have a B2150 and think that I have a similar problem. Particularly in forward, the pedal is slow to return to neutral and the tractor creeps forward. Sometimes I tap the reverse pedal to stop. I tried lubing the zirc fitting with no sucess. Will watch to see what others recommend. Good luck and good post!
   / b2710-how to adjust heavy HST pedal ? #3
Re: HST pedal slow to return to neutral
I think it is real easy, at least it is on my 1700. There are 2 springs on the HST shaft, each held in place with lock nuts. One spring controls rate of return of the pedal from the forward motion position, and one rate of return from the backward motion position. The owners manual says to adjust these nuts so the springs measure between 42 and 65 millimeters; shorter will give more spring compression and so faster HST pedal action. In my manual, this is listed as an every 100 hour maintanance check.
   / b2710-how to adjust heavy HST pedal ? #4
Oh yeah, there is also a grease fitting for the pedal as it rotates on its mounting shaft. This is supposed to get lubed every 50 hours on my 1700.
   / b2710-how to adjust heavy HST pedal ? #5
Re: HST pedal easy to adjust
Thanks Paul B! Does yours have a rubber boot around it? When I look under there I see something that looks like a mini shock absorber, can't see any springs. Will check and see if the boot or whatever it is slides off.
Will be glad when I finally get my owners manual from kubota so I won't have to ask these basic maintenance questions.
2005 Sterling Acterra Tender Truck (A56435)
2005 Sterling...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
2017 Ford F-250 Service Truck (A56858)
2017 Ford F-250...
2022 Schulte 2500 Giant Rock Picker (A55315)
2022 Schulte 2500...
2025 Wolverine SP-15-84W 84in Snow Pusher Skid Steer Attachment (A55973)
2025 Wolverine...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
