B26TLB HYDRAULIC HOOK UP SWEEPER
   / B26TLB HYDRAULIC HOOK UP SWEEPER #1
auctioneeral
shamong,NJ
KUBOTA B26TLB
B26TLB that a want to buy a skid steer sweeper to sweep road way. But I don't know how to hook up hydraulic line from sweeper to tractor because if a use 3rd function I will have to hold button in to operator sweeper. How or what could I do to operated sweeper.
B26TLB as factory 3 rd function which just as the 2 buttons mounted on joy stick which I use for a grapple.
Would I need to install a factory rear remote which looks expensive to buy.
Any idea's. I was thinking single motor spool valve and tee it into the hydraulic coming off back of tractor for backhoe.
   / B26TLB HYDRAULIC HOOK UP SWEEPER #2
what pressure and flow does the sweeper require?
   / B26TLB HYDRAULIC HOOK UP SWEEPER #3
Motor flow requirement on a sweeper important.
The B26 3rd function has about 7gpm flow. No really motor control ability.
Implements with rotational momentum unusually need free flow back to tank on exhaust side of motor.
While factory rear remotes are an option and detent an option too no real hands free flow control.
Depending flow requirements and if you need flow control ability determines your options. Might mean pto pump, tank and motor control valve.
thanks for all replys.
Do you think the forklift broom attachment would work on removing dirt off street.
   / B26TLB HYDRAULIC HOOK UP SWEEPER #7
The forklift broom would get it done, but like using a push broom, you will need to clear the bristles and make several passes, whereas the PTO broom would get it done and clean in one pass.
Really depends on your project/situation - is this an infrequent need for a few houses/sites per year to clear the surface/pavement of debris, or are you doing commercial work where this will be used over several years, and it needs to be well cleaned quickly.
   / B26TLB HYDRAULIC HOOK UP SWEEPER #8
FWIW, my town uses rear PTO sweepers all the time to clear roads from sand in the spring.
   / B26TLB HYDRAULIC HOOK UP SWEEPER #10
I don't think you can "Tee" anywhere in an open center system. Except return to tank of course.
2004 Chevrolet C5500 Shuttle Bus (A50323)
2004 Chevrolet...
CAT ENGINE ( NON- RUNNER) (A50854)
CAT ENGINE ( NON-...
2020 JOHN DEERE 3032E TRACTOR LOADER BACKHOE (A51243)
2020 JOHN DEERE...
2018 Ford Escape SUV (A50324)
2018 Ford Escape...
2013 HINO 388 (A50854)
2019 PJ 25 T/A GOOSENECK TRAILER (A50854)
2019 PJ 25 T/A...
