Buying Advice B2650
   / B2650 #11
Okay here is a update. Yesterday the local dealer dropped off a 2650 with turf tires for us to demo, no mower tho they did not have one with a mower on it. I'm sure the mower will cut nice as i have had several kubota mowers and all cut nice both mmm and front cut. Our concern was ride quality and the large turf tires and suspension seat proved very nice although the armrests on the seat we found useless. Also the 3. Had no issue lifting the aerator, however moving with it raised was not so good. I will definitely need a full set of front weights to drive with the aerator lifted, the aerator I believe is 1000-12000 lbs. it is an amazing unit, first products areivator AE-60.
All in all I really liked the tractor I just really want to be sure it will meet the tasks before I pull the trigger ��
Did the demo unit have a loader? If so, was that not enough to counter balance the aerator? Could always grab a scoop of something to get more weight too.
   / B2650
No loader it will just be in the way and it's only use would be front ballast. I have a Case SV250 and a loader on my JD5083, just don't need another loader. I'm hoping to do some front weights maybe a little bigger than the standard B size, I'm thinking about 400-500lbs should do the trick.
   / B2650 #13
Not sure how much my med. duty 5 ft. land pride rotary cutter weighs but the b front weight kit does a good job with that set up . You may get the dealer to throw that in with the purchase . I too like the 2650 and I find the arm rests work really well for me .
2014 Ford Taurus Sedan (A50324)
2014 Ford Taurus...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
Walking Floor Trailer (A50322)
Walking Floor...
Koyker Loader DoubleTine Bale Spear - Versatile for Round and Square Bales (A52128)
Koyker Loader...
2020 Takeuchi TL10V2 (A47384)
2020 Takeuchi...
2023 TAKE 3 TRAILER 3 CAR TRAILER (A52141)
2023 TAKE 3...
