B2650 what RPM when mowing?
   / B2650 what RPM when mowing? #1
Rob 80
WVA
B2650
Mine is a HST and using a belly mower what RPM should you mow at? I've been at 2,300-2,500 if a little more power is needed.
   / B2650 what RPM when mowing? #2
That's what Kubota recommends IIRC....2500 rpm. That's what I use...2400-2500. You can slow down your forward speed if in deeper grass.
   / B2650 what RPM when mowing? #3
My BX2200 does not have a tach. Run it full out when mowing with the MMM.
On my B2910, with the brush hog, I run it at the rpm that equates to 540 pto rpm.
I think this is pretty standard operation...
   / B2650 what RPM when mowing? #5
I set mine at whatever rpm it takes to spin the back pto 540 rpm. I think it's about 2400 rpm. I'm not sure what the front pto speed is when the back is 540 but the torque should be the same. You can punch that rubber button to shift b/w engine rpm and pto rpm.
   / B2650 what RPM when mowing? #6
deleted - skipperbrown beat me to it - rash button
2015 CATERPILLAR 326FL LONG REACH EXCAVATOR (A51242)
2015 CATERPILLAR...
2006 Ford Crown Victoria Sedan (A50324)
2006 Ford Crown...
2014 RAM 5500 FLATBED TRUCK (A51222)
2014 RAM 5500...
2015 DODGE RAM...
2020 KUBOTA RTV...
71067 (A49346)
71067 (A49346)
