B2650 tie rod end boot.
   / B2650 tie rod end boot.
I noticed mine had popped out of place, luckily it wasn't torn or damaged at all. I dislike the curly wire spring deal they use to hold them in place, it was a bear to get pushed back where it needed to be.
Mine came loose to because of the spring and i put it back a couple of times.The guard got bent and ripped it off.
Here are a couple of Kubota part numbers that may work:
35080-44680
Kubota: COVER, RUBBER DU, Part # 358-4468
K1253-01660
This is what I used on my B3030. The cost was around $11. I think it was a wee bit smaller than the original boot but it fits and works just fine.
Picture copied from this thread:
http://www.tractorbynet.com/forums/parts-repairs/310869-replacing-bx24-tie-rod-boot.html
If my homemade boot fails i will give this a try.Thanks.
2009 L3 GENERATOR SET (A51222)
2009 L3 GENERATOR...
2016 Ford Escape SUV (A50324)
2016 Ford Escape...
2018 John Deere S780 Combine (A50657)
2018 John Deere...
197359 (A50458)
197359 (A50458)
2013 CATERPILLAR 420F BACKHOE (A51242)
2013 CATERPILLAR...
2018 Skyjack SJ1056TH 10,000lb 4x4 Rough Terrain Telehandler (A49461)
2018 Skyjack...
