B2650 on B7500?
/ B2650 on B7500? #1
Rusty
Hampton Township, Bay County, Michigan
Kubota B7500HSD-R
I'm looking at a B2650 front mount snowblower for use on my 2003 B7500 HSD. The snowblower was bought new with a 2004 B2410 HSD. Both tractors have FELs (LA302, LA352) and RCK60-24B MMMs. Does anyone know if the subframe and PTO are the same for both tractors? Also, the current owner of the snowblower says that he does not have to remove the FEL frame or MMM front attachment bracket to install the snowblower. Can anyone confirm this? Any other comments on the B2650? Thanks, in advance!
/ B2650 on B7500? #2
Hello rusty, that subframe doe's fit both the 7500 & the 2410, installation of the subframe is actually easy if you have a fel. If you purchase the 2650 send me a pm i can give you some information on that unit that will save you some pain, i ran a 2650 on a B7500 for years, its a good rig but it needs some modifications for serious snowblowing. Scott
/ B2650 on B7500?
Thanks, Scott! Did you also have a mmm on your B7500? If so, did you have to remove the mmm front attachment bracket to install the B2650? I seem to remember reading that here on TBN, but have been unable to find the post in my searching.
/ B2650 on B7500? #4
I did not have a mmm, i would guess you need to remove the subframe for the mower. It's only 4 bolts to remove the subframe if you have a fel. Kubota also offered a B2019, 60" power angle plow for the same subframe, best plow i ever owned.
2020 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61568)
2020 Chevrolet...
1901 T/A CAR HAULER TRAILER (A59914)
1901 T/A CAR...
2015 FORD F-350 SUPER DUTY (A63569)
2015 FORD F-350...
2020 Club Car Carryall 700 Gas Utility Cart (A61567)
2020 Club Car...
2001 INT 4900 DT 530 (A62679)
2001 INT 4900 DT...
2018 CATERPILLAR 573D FELLER BUNCHER (A64276)
2018 CATERPILLAR...
