B2650 oil change question?
   / B2650 oil change question? #1
jodebg
Platinum Member
New Hartford, CT
Kubota B-2650
Need to do an oil change on my B2650. There are 2 threaded caps on the top of the engine that have "oil" embossed on them.
Are they both used for refilling the engine oil? Any advantage to using one or the other?
   / B2650 oil change question? #2
I use the one on the right side. Easier to get to.
I don’t think I have ever used the one on the valve cover.
   / B2650 oil change question? #3
Either one will work and there is no difference. Kubota does this because most of their engines are used in other aplications where one oil fill may be completly blocked. I am pretty shure I used the valve cover hole to fill my b2650.
   / B2650 oil change question? #4
Either oil filler can be used. This same diesel engine is also used extensively in the asian market for Diesel Gensets.
   / B2650 oil change question? #5
Same for JD and Isuzu. One on top will take higher flow without backing out because it's straight in and not at a slant. Just stick a funnel in it and pour. Cannot do this with the side one.
Ralph
2007 INTERNATIONAL SF625 BUCKET TRUCK (A50854)
2007 INTERNATIONAL...
2010 CAT 140M MOTORGRADER (A50854)
2010 CAT 140M...
2014 FORD F-350 SUPER DUTY CREW CAB FLATBED TRUCK (A51243)
2014 FORD F-350...
2019 CATERPILLAR 259D SKID STEER (A51242)
2019 CATERPILLAR...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
2016 Ford F-150 Ext. Cab Pickup Truck (A50323)
2016 Ford F-150...
