B2650 MMM Pin Up
   / B2650 MMM Pin Up #11
I have to raise the 3pt almost all the way up and then slowly lower it down about an inch - this gets the bracket holes close to lining up, at the same time i use a floor jack to raise the edge of the deck a little bit until one side goes in. Then off to the other side.
   / B2650 MMM Pin Up #12
I have seen somewhere, someone had an extension added so their pinning holes were much lower. Do you have those? With mine, the back of the mower hits the stoppers but the front isn’t up enough to line up the holes. That’s why I need to manually lift it to make the holes line up.
   / B2650 MMM Pin Up
Forget This!!!
I just spent about two hours of arm and knee wrenching removing the the (four) bolts on the (two) rear deck stops.........pulling the cotter pins..........jacking up the MMM to where the holes for the two pins almost, but not quite line up. And then put it all back together. Chit, it wasn't worth it.
Thanks anyway,
Mike
   / B2650 MMM Pin Up #14
I'm getting ready to get something a little bigger than my BX2370. Been debating between the B2650 and B2601. Reading this makes me think that the B2601 might be a better option with the suspended deck as opposed to the ground contact deck on the B2650.
   / B2650 MMM Pin Up
I kinda like the suspended deck on my B2620. It has a cam that allows the deck to be held in the up position. There were a couple issues with it too. One problem was the light welds on a front wheel hanger.... Had to re-weld it a couple times. The other was the cam part wore out after several years. That could have been accelerated by hanging the Cyclone Rake boot /tube apparatus on the deck for leaf collection. But, "Hey" i still have it and still use it.
But my B2650 deck is more stout even though I have abandoned the "pin up" procedure.
Cheers,
Mike
   / B2650 MMM Pin Up #16
No issues with the terrain following decks on my B1750 and B3350, and a terrain following deck is considerably more versatile than is a suspended deck.
SDT
   / B2650 MMM Pin Up #17
Agree with SDT on the terrain following deck. My experience with it is a 60" deck on a B2150. Does a better, smoother job of cutting it seems to me compared to my BX2200 using the same size deck but suspended type. Not really sure why.
   / B2650 MMM Pin Up #18
Pin up should be seamless and doable in seconds.
Confused here. Are you attempting to pin up the MMM or the lifting mechanism once the MMM has been removed. Two entirely different procedures but both are discussed in the mower owners manual.
You may not be able to pin up either if the mower was not properly installed and adjusted. Again procedures are in the manual.
SDT
Do you have the pin-up instructions!?!!?!#$^%!@#$ - I've having a heck of a time finding it online! Seems like it would be simple.....seems... TIA!
   / B2650 MMM Pin Up #19
As previously mentioned, you need the Mower Operator's Manual and, maybe, the Mower Installation Manual.
Doubt that you will find either online but your dealer can get such for you if he is willing to be bothered.
   / B2650 MMM Pin Up #20
I have the B2650 operators manual, the work shop manual and the MMM 60" manual + parts list.... I'm not finding anything about "pinning up" the lift arms as of yet.... :/ just happed across it in a couple forums where people talk about it with no documentation....
2013 ORTEQ ENERGY GN182 GOOSENECK HOSE TRAILER (A58216)
2013 ORTEQ ENERGY...
2018 RoGator 1100C (A56436)
2018 RoGator 1100C...
UNUSED FUTURE FT-RT57 - 57" HYD ROTARY TILLER (A52706)
UNUSED FUTURE...
Genie GTH 844 Telescopic Forklift (A57148)
Genie GTH 844...
BEFCO 10 WHEEL V-RAKE (A52708)
BEFCO 10 WHEEL...
2017 Komatsu WA500-8 Articulating Wheel Loader, S/N A96097, PIN# KMTWA134LGNA96097, Komatsu Turbo (A59076)
2017 Komatsu...
