B2650 Hood w/strip repair
   / B2650 Hood w/strip repair #1
BubbaJr
Platinum Member
Western Ohio
2016 KUBOTA B2650 w/cab & A/C
I was doing my 50 hour service (a little late) on my tractor today. I pulled the plugs on the oil pan and while I was waiting for the oil to drain I grabbed the hanging w/strip off the bottom of the hood and took a good look at it. I decided to get out my w/strip adhesive and run a bead of it along the bottom lip of the hood. Then I was going to put a bead in the groove of the w/strip.
Before I put any glue on the w/strip, I noticed that there is a metal strip inside the w/strip. I found that I could squeeze the w/strip to tighten up the groove. Then I proceeded to push the w/strip on the rim of the hood. It seems to be a lot tighter, but I'll let the adhesive cure before I get too excited about the repair. I'll check it again tomorrow and see if it seems like it will hold, and let you know how it works out.
Joe :)
   / B2650 Hood w/strip repair #2
Joe :)
Pics, or it didnt happen ;)
I finished working on the tractor this afternoon. After I got done I grabbed the hood w/strip and gave it a gentle tug, AND IT DIDN'T MOVE.:cool2: Before if you looked at it sideways it would fall off. If I have further problems with it, I'll let you know.
Joe
   / B2650 Hood w/strip repair #5
Seems to be a problem with those strips. I was always putting mine back on. Squeezed mine and glued both. No more problem.
   / B2650 Hood w/strip repair #6
How about somebody post some pictures on this subject. Not everybody knows what your talking about...me included.
90018 (A48082)
90018 (A48082)
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51248)
(2) METAL SPOOLS...
CATERPILLAR CS563 SMOOTH DRUM ROLLER (A51246)
CATERPILLAR CS563...
UNUSED CFG QK18R EXCAVATOR (A51247)
UNUSED CFG QK18R...
UNUSED RAYTREE RMLL60-60" POWER RAKE LAND LEVELER (A51248)
UNUSED RAYTREE...
