B2650 Hood w/strip repair
   / B2650 Hood w/strip repair #1
BubbaJr
Platinum Member
Western Ohio
2016 KUBOTA B2650 w/cab & A/C
I was doing my 50 hour service (a little late) on my tractor today. I pulled the plugs on the oil pan and while I was waiting for the oil to drain I grabbed the hanging w/strip off the bottom of the hood and took a good look at it. I decided to get out my w/strip adhesive and run a bead of it along the bottom lip of the hood. Then I was going to put a bead in the groove of the w/strip.
Before I put any glue on the w/strip, I noticed that there is a metal strip inside the w/strip. I found that I could squeeze the w/strip to tighten up the groove. Then I proceeded to push the w/strip on the rim of the hood. It seems to be a lot tighter, but I'll let the adhesive cure before I get too excited about the repair. I'll check it again tomorrow and see if it seems like it will hold, and let you know how it works out.
Joe :)
   / B2650 Hood w/strip repair #2
Joe :)
Pics, or it didnt happen ;)
I finished working on the tractor this afternoon. After I got done I grabbed the hood w/strip and gave it a gentle tug, AND IT DIDN'T MOVE.:cool2: Before if you looked at it sideways it would fall off. If I have further problems with it, I'll let you know.
Joe
   / B2650 Hood w/strip repair #5
Seems to be a problem with those strips. I was always putting mine back on. Squeezed mine and glued both. No more problem.
   / B2650 Hood w/strip repair #6
How about somebody post some pictures on this subject. Not everybody knows what your talking about...me included.
UNUSED AGT SDA 140W WHEEL LOADER (A51247)
UNUSED AGT SDA...
(APPROX 60) DIAMOND TREAD DBL AXLE FENDER BACKS (A51247)
(APPROX 60)...
RYOBI 40V BRUSHLESS ELECTRIC 20" PUSH MOWER (A51248)
RYOBI 40V...
2020 DEERE 318G SKID STEER (A51246)
2020 DEERE 318G...
Tradewinds Power Unit (A50120)
Tradewinds Power...
ECHO GT-225 GAS WEED EATER (A51248)
ECHO GT-225 GAS...
