B2630 won't start
/ B2630 won't start #11
7 year old tractor-simple answer-replace the battery. Went through the same process with my 8 year old B2620 this past June. Backed out of the barn, turned it off, went to start it -10 minutes later-nothing. Checked fuses, rocker pedal location-put charger on it, nothing, tried to jump it with the RTV-could get the solenoid to click-that's all.
Bought a new battery-done.
Will
Will
/ B2630 won't start #12
Deleted-duplicate post
/ B2630 won't start #13
Did you disengage the pto?
/ B2630 won't start #14
That happened to me in a similar situation, on my then b2620 there is a safety switch underneath the tractor on right side. It engages when you press the brake pedal. It was just stuck. At least that is what I remembered.
/ B2630 won't start #15
After the battery/starter are proved look at any switches that could have been moved etc. When the mower was put on and any that involve the mower.
Lack of power sounds like lack of fuel to the injectors.
Might also check the mower for free movement of the blades.
Bobcat E42 (A60462)
Bobcat E42 (A60462)
WOOD GRABBER FOR MINI EXCAVATOR (A58214)
WOOD GRABBER FOR...
MANIFOLD TRAILER (A58214)
MANIFOLD TRAILER...
UNUSED FUTURE SB45 HYD SILENT BREAKER (A52706)
UNUSED FUTURE SB45...
2002 Allmand Night-Lite Pro Towable Light Tower (A56857)
2002 Allmand...
207277 (A52708)
207277 (A52708)
