B2630 Tractor won't start
   / B2630 Tractor won't start #1
ezatu
Don't know if this is the correct place to list......
We have a B2630 tractor. When I turn the key it fires right up but dies as soon as I let go of the key. Tractor has fuel and fuel filter goods good also. I'm thinking there must be a fuel relay solenoid gizmo somewhere that may need replacement. Looking for direction and photos if possible.
thanks[SUP][/SUP]
   / B2630 Tractor won't start #2
There are also 2 start/run-related fuses on the B3030. So check to see if you have the same ones on yours. One of them is for the fuel solenoid, and the other is the Operator Presence Control, or whatever they call it. That one is a 5 amp fuse, and there are 2 switches under the seat, so you may want to start with those - they can get finicky in time.
   / B2630 Tractor won't start #3
On my bx 2350 there's a injection pump solenoid,its on the same side of the engine block as the injection pump
There's a wire going into the solenoid that is electrically activated/deactivated. When you turn your key on to the run position does the solenoid move[you'll beable to see the linkage move] same as when you turn the key to start does it move then.If it only moves while in the start position and shuts off in the run position then you more then likely have problems with your key switch.Not sure if your tractor sits out in the rain etc: but your switch could be coroded inside.At least the movement of the solenoid is Something you can check just by watching it as you turn your key to run,start,or off.
Peterbilt 377 Semi-Truck (A56438)
Peterbilt 377...
2017 Mercedes Benz GLA SUV (A56859)
2017 Mercedes Benz...
CASE IH MX220 MAGNUM TRACTOR (A57192)
CASE IH MX220...
2002 Ford Thunderbird Convertible (A59231)
2002 Ford...
Deere 333E (A60462)
Deere 333E (A60462)
Zero Turn Mower (A59231)
Zero Turn Mower...
