B2630/B3030 total pump output
/ B2630/B3030 total pump output #1
Stef
Platinum Member
South Quebec, Canada
Kubota B3030 TLB, TYM 330
I'd like to know why the total pump output of a B2630 is different (higher) than a B3030?
B2630: 9.8 gpm
B3030: 9.1 gpm
I don't understand, even a B2710 has more output (9.5 gpm). I asked my dealer, but he didn't know and he didn't seem to have the will to search and get an answer.
I don't think it's a dumb question since I searched everywhere and didn't find the reason. I tried to look the part numbers of the pump on Tractorsmart but I only got the number for the B3030, B2910, B2410. I tried but I cannot have access to part numbers for B2630, B3030hsd (cab version) and B2710.
/ B2630/B3030 total pump output #2
B2630 has 5.6 gpm main pump + 4.2 gpm steering pump
B3030 has 5.2 gpm main pump + 3.9 gpm steering pump
JerryG, thanks... that's what my dealer told me. But it doesn't tell me why there's a lower output from a B3030 though. /forums/images/graemlins/confused.gif It's like buying a L5030 with 41hp. It doesn't make sense. There must be a reason for that. A B3030 is the next model after a B2630 and it's more expensive but it has less pump output... I should consider myself lucky to have more horsepower than a B2630. Why they didn't build a B3030 with 22hp then?
/ B2630/B3030 total pump output #4
I agree that it doesn't make since. The only way that you could find out would more than like be to speak to one of the engineers that worked on these tractors originally.
/ B2630/B3030 total pump output #5
Does it have to do with the 2630's higher rpm'S ?
/ B2630/B3030 total pump output #6
My understanding is that the B2630 and B3030 are the same tractor with different size engines. I did note that the B2630 is rated at 2800, B3030 at 2600 rpm's. 200 less RPM's would have less output from the same pump.
/ B2630/B3030 total pump output #8
I agree with Mr. Hall. The 200rpm could account for the additional .7gpm from the same pump. Kubota probably doesn't see it as an issue as 9.1gpm surpasses the flow requirement of any Kubota made option for that model.
/ B2630/B3030 total pump output #9
<font color="blue"> Mr. Hall </font>
Thanks /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif
Ron works to. /forums/images/graemlins/wink.gif
ronjhall,... sorry Mr. Hall /forums/images/graemlins/grin.gif, I think you have a point here. 200 rpm, could be the cause of it. To be sure, I'll ask my dealer if the two pump part numbers are the same. If it is then it's the rpm for sure.
Thanks, sometime it's right under your nose and you don't see it.
/ B2630/B3030 total pump output #11
The rpm shouldn't have anything to do with the pump out put in gpm. The relief is set below max rpm. Like Neil said, the casting has to be different. The max gpm is determined by the diameter and thickness of the gears in the pump.
/ B2630/B3030 total pump output #12
Relief is for max pressure. GPM output is controlled by RPM's and size of pump.
/ B2630/B3030 total pump output #13
You would think that by now that I would know not to post when my migraines are real bad. Each rotation of the pump is x amount of cc's. The more rpm the more gpm. Does anyone have a shop manual for these two tractors? I still bet that the housing is different for the pumps. I will be back tomorrow.
/ B2630/B3030 total pump output #14
Had one of those headaches yesterday. /forums/images/graemlins/frown.gif Hope you get over it soon.
It sure would be a good piece of information if we knew if pump was the same. For what its worth, B2710 and 2910 have the same pump.
JerryG, I'm sorry if my question causes you migraines. I'll stop asking that kind of question in the future. /forums/images/graemlins/grin.gif /forums/images/graemlins/grin.gif
Hope you get well soon /forums/images/graemlins/wink.gif
2013 FORD F-350 FLATBED (A58214)
2013 FORD F-350...
KIVEL 48" PALLET FORKS 3500 LB CAP (A60430)
KIVEL 48" PALLET...
2025 DIGMASTER DM100 EXCAVATOR (A60430)
2025 DIGMASTER...
2008 KENWORTH T300 FLATBED FUEL TRANSPORT TRUCK (A58214)
2008 KENWORTH T300...
TANK MANIFOLD (A58214)
INTERNATIONAL FLAT BED TRUCK (A52707)
INTERNATIONAL FLAT...
