B2620 VS. JD2320 Little Help
   / B2620 VS. JD2320 Little Help #11
My brother has a 2920. The FIL will only take a few minutes to attach once you do it a couple of times. He paid $17,200 before tax for the 2920, FIL, R4s, 60" deck, and 54" Landpride tiller, that was 9 months ago. I have no doubt you can come in well under budget on the 2620. The 3 range HST is the major difference in the 2 machines. I can tell you, if you ever do get a hoe, you will be relegated to Low range with the Deere. It is basically a 1 range machine if you live in the hills like I do. That Medium range is the difference maker. Plus, it's cheaper.
   / B2620 VS. JD2320 Little Help #12
If you are mostly mowing I would consider the turf tires. I have a B3030 with turf tires. I have a dedicated ZTR for mowing and use the tractor for snow removal with a front blade. I also brushcut fields and use the FEL for debri removal, carrying firewood, and gardening. I am very happy with turf tires and prefer them over R4. The turf tires are likely better for your lawn and provide good traction at least for my uses.
   / B2620 VS. JD2320 Little Help #13
I have turf tires and they work pretty good. Good in the snow and on the grass. They don't work to bad in a little bit of mud, but in really heavy mud, they are pretty bad. When its that muddy, it's not any fun working anyway, so I just park it.
   / B2620 VS. JD2320 Little Help #14
I would put my nod to the turf tires as well, especially for mowing. My R4's will tear up the grass a little with the front outside tire in a tight turn. I never had this problem with my turfs before on my B7200. The turfs seemed to do just fine even plowing snow. The turfs may actually seem better when plowing/grading my gravel driveway, I think the flat bar tread on the R4's have a tendency to ride on top of loose gravel like marbles versus the turfs letting the rocks in the tread. I never had a BH or FEL on my old B7200, but I use all the same 3pt implements with both tractors and their weight is about the same.
   / B2620 VS. JD2320 Little Help #15
I actually have loaded R-4's on my 2620. I agree they will slightly tear the lawn a little in tight turns but not to bad. I dont mow w/ mine and have a dedicated ZTR so this is the reason I went w/ the loaded R-4's most of my work is done in woods on some wet spots, and will be done leveling about a 2 acres back field When I am on the "good lawn" I just dont make that tight of turns and I have no problem. If this will be your primary mower than I vote for the turfs as well.
   / B2620 VS. JD2320 Little Help #16
I have the optional bar/turf tires. You can find them on Kubota's configurator as there are two turf tire setups. It's basically a turf tire up front and a modified bar tire in the back. I'm happy as they are easier on the lawn and I haven't needed chains for any of my snowblowing work. See pic.
   / B2620 VS. JD2320 Little Help #17
You said you had some woods to clean up. Keep in mind that the R4's are a lot more puncture resistant than the turfs.
   / B2620 VS. JD2320 Little Help #18
I mow with an L2800 and I have loaded R4s and don't have any problems, even when its wet. If it will be a dedicated mowing machine, then get the turfs. If you have other chores in rougher terrain that will require some bite, get the R4s.
UNUSED FUTURE HYD HEDGE TRIMMER (A52706)
UNUSED FUTURE HYD...
2015 WESTERN STAR 4900 GLIDER TANDEM AXLE DAY CAB (A59575)
2015 WESTERN STAR...
*Selling at Royal Auction Tampa, FL Location* (A59230)
*Selling at Royal...
2002 Chevrolet C8500 Flatbed - CAT 3126 Diesel - Eaton Fuller 8 plus 2 Transmission (A56438)
2002 Chevrolet...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
30 INCH TOOTHLESS BUCKET FOR MINI EXCAVATOR (A58214)
30 INCH TOOTHLESS...
