b2620 MMM
   / b2620 MMM #1
lawn_master
I have a 2620 with a mmm. I want to use the rear PTO while the mower is attached. How do I lock the MMM in place so when I put the rear PTO up and down the mmm does not move? Can this be done and how? Thanks in advance
   / b2620 MMM #2
Set the height dial to "top". If that doesn't work, you can pin it up (if the holes line up for ya).
   / b2620 MMM
does not move in the top position. Thanks
   / b2620 MMM #4
I would reccommend putting the pins in the front as well. They are a little tricky to get in and out. They should have come with the mower and are usually stored in the back brackets of the MMM.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
Roll of 2-inch Vacuum Hose (A57454)
Roll of 2-inch...
5' ROTARY MOWER (A52706)
5' ROTARY MOWER...
TOPCAT HCRC 72" HYD BRUSH CUTTER (A52706)
TOPCAT HCRC 72"...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
