B2620 independent wheel braking?
   / B2620 independent wheel braking? #1
BrierPatch
West Central Indiana
Kubota B2620 364 FEL, BH65, 60" MMM
I was working in the woods tonight and grappled a log with the BH. This made the front end light enough that I had trouble steering. I noticed that I could use my heel on the hst fwd pedal and push the left wheel brake at the same time. So I unlocked the brake pedals and tried it. I was surprised when it didn't help me turn at all. All it was doing was like dragging the brakes on both wheels. It was just putting a load on the tractor. Has anyone tried this or had different results?
By the way who says you need a thumb on the backhoe!
(It was late and all I had was my cell phone camera.)
   / B2620 independent wheel braking? #2
That should be called a Dipper Thumb!:D
Nice trees.:D er, unassembled furniture!:D
   / B2620 independent wheel braking? #3
I'd say experiment with your split brakes. I'm on my third compact tractor (second Kubota), and i couldn't live without split brakes. Perhaps your brakes need adjustment?
   / B2620 independent wheel braking? #4
My guess is you must have had your differential lock on. I brake steer my Kubota all the time. If the differential lock was on it would not work.
   / B2620 independent wheel braking? #5
The differential lock is engaged with a lever on the left side below the seat near the floor. You have to keep it depressed to engage the differential lock, so I doubt that would be the problem.
   / B2620 independent wheel braking? #6
Other than a serious problem in the differential. I can not think of a single thing that would cause the problem described other than the differential lock being engaged.
I agree about the diff lock. It is the only thing I could think of. I had used it earlier that night, but I had made many manuevers (fwd/rev and turning) since I used it. I am guessing that it must have, or still is, stuck.
If it is stuck, anyone ever have this problem or know how to unstick it?
2020 Kinze 3505 High Speed 6/11 Planter (A53472)
2020 Kinze 3505...
UNUSED CHERY INDUSTRIAL 7' - 10 DRAWER WORKBENCH (A51248)
UNUSED CHERY...
2007 Freightliner B2 School Bus (A51692)
2007 Freightliner...
Toro Workman Low Profile Spray system 200 (A50322)
Toro Workman Low...
NEW Slip On Fork Extensions (A53002)
NEW Slip On Fork...
