B2620 50 Hour Service
   / B2620 50 Hour Service #1
Botabill
Platinum Member
Ontario
Well it doesn't take long to rack up the first 50 hours on a new tractor. Bought my B2620 last fall and needed to do the first 50 hour service this weekend. I called the dealer to ask how much they wanted to do the job and it was an unbelievable $350. Sounded pretty steep to me considering all that has to be done is change 3 filters, the engine oil and top up the hydro fluid so I decide to do it myself.
First the engine oil. Seemed simple enough ... pull the plug in the oil pan and let it flow out. Well let me tell you with a loader installed the plug is hidden up under the loader support arm and required some serious acrobatics to jiggle it loose. Hey Kubota! Why not put a hole through the loader support arm to allow a socket easy access to the drain plug. The way it is the oil has to drain down on the support arm and dribbled this way and that to finally drip into the catch pan if you're lucky.
Changing the filter was a whole lot easier however the front grill and left side engine cover needed to be removed to get to it. At first I was intimidated by the prospect of this task however the good thing for this maintenance and other engine work is these part come off in seconds. Off comes the old filter and on screws the new one. Reinstall the engine covers. Fiddle some more to put the drain plug back in and fill it up with oil. Next...
Changing the hydraulic and hydrostatic filters. Both are generally easy to get to from under the tractor. Simply unscrew the old ones and quickly screw in the new one. Make sure you put the right filter on the correct side. You will have a little hydraulic fluid loss but only about a quart which is easily topped up. In all it took me 2 hours. I wasn't in a hurry as I was sipping a cool one and enjoying exploring the new tractor. The final cost for oil, filters and hydraulic fluid was under $100. Looks like I earned $250 for 2 hours work. Not bad!
   / B2620 50 Hour Service #2
I thought you have to change the transmission fluid at 50hrs, but I just check my BX manual and it shows 1st change at 400 hrs. I will probably still change at 50 hrs. Both my Grand L and my RTV 900 show change required at 50 hrs. Your dealers quote might have included transmission fluid change.
Gary T.
   / B2620 50 Hour Service #3
Thanks for the run-down. My BX2350 is approaching the 50-hour mark and from reading here, it's looking like I'll be tackling this myself.
In retrospect, would it have been worth your time to remove the FEL?
   / B2620 50 Hour Service #4
That was a WTF moment for me too. A little bit forward or backwards and it would've cleared it. I ended up removing the plate for the oil change.
   / B2620 50 Hour Service #5
Looks like I want to remove the FEL before I have to do this on mine.
I could have swore that the 50 hour service on my 2920 has a complete change of the transmission oil.
Larry
Gary T.
My BX 1800 manual did require a full hydraulic fluid change but not the B2620 nor for my Kubota excavator.
Gary T.
Yes the dealer quote did include changing the Hydraulic fluid at $78 for the fluid but according to the maintenance shedule that is not required.
The problem was the permanently installed support that isn't really removable. Even when the FEL is off the machine these things are still on the tractor.
   / B2620 50 Hour Service #9
Piece of cardboard to act as a funnel to clear the cross piece makes it much easier to route the fluid drainage.
   / B2620 50 Hour Service #10
I had my dealer do the 50 hour service on my 2620 and they changed the hyd fluid. The maintenance schedule doesn't show it at 50, but they recommended it. I had them throw in the block heater too.
(30) 9' Pipe Fence Posts (A50515)
(30) 9' Pipe Fence...
2002 GREAT DANE 102" X 53' T/A VAN TRAILER (A51243)
2002 GREAT DANE...
2013 VOLVO VNM TANDEM AXLE DAY CAB (A52141)
2013 VOLVO VNM...
New Calf Hut (A50515)
Unused Delta Crash...
2019 TAKEUCHI TL8 SKID STEER (A51242)
2019 TAKEUCHI TL8...
