B2601 work light wiring?
/ B2601 work light wiring? #1
grandall4
Granby MA
Kubota B2601 & Z725
As anyone located extra wiring for work lights like the BX and other models have? I looked under the fenders and didn't see any obvious extra connections.
/ B2601 work light wiring? #3
I believe the plugs for the tail lights are bullet connectors on the B series as well. The Kubota lights that I purchased wire in line with the tail lights, and have a separate switch if you do not need them. I will look at my B2601 Wednesday when I put my LED lights on it, and post again.
/ B2601 work light wiring? #4
The extra wires on my B2601 are blue color taped to the wiring harness under the right rear fender above the tail light.
/ B2601 work light wiring? #5
Yep, B series it's under the right fender. L series it's under the left fender. Those are the only two Kubotas I have owned, so my knowledge runs out there.
/ B2601 work light wiring? #6
I installed the 2 LED light fixtures that I purchased from Kubota that were installed on my old BX1860. They installed into the tail light wiring just like the instructions from the kit. There are bullet connectors that connect the tail lights and this kit connects in line with those lights, but the LED lights are also polarity sensitive. This gives me a light fixture on each side above my head on the ROPS so that the loader does not block all the light.
2012 STEPHENS CRUDE PUP TRAILER (A67714)
2012 STEPHENS...
2013 VOLVO A40F OFF ROAD DUMP TRUCK (A65053)
2013 VOLVO A40F...
LINCOLN ARC WELDER (A67714)
LINCOLN ARC WELDER...
IRRIGATION PIPE FITTINGS (A64276)
IRRIGATION PIPE...
2014 Chevrolet Impala Sedan (A61574)
2014 Chevrolet...
2016 VOLVO A40G OFF ROAD DUMP TRUCK (A65056)
2016 VOLVO A40G...
