B2601 work light wiring?
   / B2601 work light wiring? #1
grandall4
Granby MA
Kubota B2601 & Z725
As anyone located extra wiring for work lights like the BX and other models have? I looked under the fenders and didn't see any obvious extra connections.
   / B2601 work light wiring? #2
The extra wires on my BX are under the seat.
   / B2601 work light wiring? #3
I believe the plugs for the tail lights are bullet connectors on the B series as well. The Kubota lights that I purchased wire in line with the tail lights, and have a separate switch if you do not need them. I will look at my B2601 Wednesday when I put my LED lights on it, and post again.
   / B2601 work light wiring? #4
The extra wires on my B2601 are blue color taped to the wiring harness under the right rear fender above the tail light.
   / B2601 work light wiring? #5
Yep, B series it's under the right fender. L series it's under the left fender. Those are the only two Kubotas I have owned, so my knowledge runs out there.
   / B2601 work light wiring? #6
I installed the 2 LED light fixtures that I purchased from Kubota that were installed on my old BX1860. They installed into the tail light wiring just like the instructions from the kit. There are bullet connectors that connect the tail lights and this kit connects in line with those lights, but the LED lights are also polarity sensitive. This gives me a light fixture on each side above my head on the ROPS so that the loader does not block all the light.
2015 VOLVO ECR88D (A50854)
2015 VOLVO ECR88D...
1266 (A50490)
1266 (A50490)
2020 CATERPILLAR Tl1255D TELESCOPIC FORKLIFT (A51242)
2020 CATERPILLAR...
2011 CATERPILLAR D9T HI-TRACK CRAWLER DOZER (A51242)
2011 CATERPILLAR...
2019 CATERPILLAR D5K2 LGP CRAWLER DOZER (A51242)
2019 CATERPILLAR...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
