Sid Post
Platinum Member
- Joined
- May 28, 2010
- Messages
- 757
- Location
- TX and OK
- Tractor
- Massey 5711D, Kubota L4600, Kubota B2601
I need a smaller tractor bigger than a BX on my 40-acre homestead and out on the farm. The BX's I have use have too little ground clearance, tires are too small for a pasture, and they lack torque to pull any descent grass load mowing my front yard with a 54" deck.
Primarily, I'm debating a B2601 against a B2650. Perhaps I should wait for the 33HP LX which my local dealer will get in early Summer.
In real-world use, how do these tractors compare to each other? I have been told the B2650 is top heavy so, it won't be a good option for the more sloped areas of my pasture and around pond dams. I can get the BX under trees easy enough and the B2601 hood and seat height aren't too far off. How are sightlines mowing on these B's? Will the larger displacement B2650 engine have more torque or a tangibly better torque curve?
Why would you choose one over the other assuming a 60" MMM and/or a 5' brush hog (shredder) to used in and around pastures, ponds, damns, and orchards?
TIA,
Sid
TIA,
Sid
