B26 with rotary cutter installed
/ B26 with rotary cutter installed #1
SamWalton
Platinum Member
Sallisaw Oklahoma
Kubota B26 TBL
I have been taking the time to install and test our implements. While removing the back hoe I found a sleeve or collar was missing on the lower link. I installed the new sleeve while installing the rotary cutter. I have also installed the rear blade. I will install and test the PD15 auger and box rake later. I made many adjustments to get the cutter in its proper position. I will read up on the theory and methods of adjustments of the three point and proper positioning of the cutter. Any advice is welcome.
2009 Chevrolet Silverado 1500 4x4 Ext. Cab Pickup Truck (A64556)
2009 Chevrolet...
32" Smooth Lip Mini Bucket  (A62679)
32" Smooth Lip...
New/Unused Electric Winch (A65583)
New/Unused...
Stout Rock Bucket Grapple HD72-3 (A66285)
Stout Rock Bucket...
Stryker 1.5 yard Slide in Spreader Box  (A62679)
Stryker 1.5 yard...
Lesco 50Lb Push Spreader (A64557)
Lesco 50Lb Push...
