B26- Runs but shuts down before moving
   / B26- Runs but shuts down before moving #1
Chickentractor
Washington
Kubota B26 TLB
I have a B26 with 150 hours on it. It starts and idles well. When I put it in gear it will creep forward and back, but if I depress the speed control pedal past a creep it shuts down immediately. There seems to be a clicking noise that corresponds with the amount of pedal depression that causes the shut down, like a safety switch.
I have eliminated the seat switch as the cause, and moved on to the neutral safety switch. It looks to be working properly but I have not attempted to adjust it. All references I can find suggest the tractor shouldn't even start if this switch is malfunctioning.
Should I proceed with adjusting the neutral safety switch or does someone have another idea? Thank you.
   / B26- Runs but shuts down before moving #2
IMHO I would bypass the switch, ie hold it closed, and see what happens. I had the same problems with an old 2200 and a 2620 I had and zip tied the switch . Problem solved. When I traded them in I showed the dealer the zip tie and mentioned he might want to fix the switch.
   / B26- Runs but shuts down before moving #3
The tractor "thinks" you are not in the seat, therefore when you press the "go" pedal the engine fuel stop solenoid snaps shut. Seat switch has 2 sections, test it with a good VOM or replace it or bypass it.
The results are the same with the switch wired, not wired, or bypassed with a jumper, so I believe it is not the seat switch (at least not at the switch end).
   / B26- Runs but shuts down before moving #5
If the safety switches are failing you will not be able to start. Since it starts and idles I would inspect the linkages and see if a wire is being pinched when you move the accelerator.
Can you track down the location of the click you are hearing?
   / B26- Runs but shuts down before moving #6
Thank you. It is a B26 so I will look up the same for that model.
   / B26- Runs but shuts down before moving #8
Check fuel water separator, if it is cold and there is water in there and it's frozen engine may not be getting enough fuel
   / B26- Runs but shuts down before moving #9
my B26 has done this, check the switch in front and slightly under the seat that lets the tractor know the seat is in the forward facing position.
   / B26- Runs but shuts down before moving #10
Seat switch or seat rotation switch b26 has 2 switches
2016 Isuzu NPR Beverage Box Truck (A51692)
2016 Isuzu NPR...
ITEM LOCATION LOT NUMBER 3 (A53084)
ITEM LOCATION LOT...
2011 Ford Fusion SE Sedan (A51694)
2011 Ford Fusion...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2014 Kubota B2320 (A50123)
2014 Kubota B2320...
