B26 Hydraulic line damage
/ B26 Hydraulic line damage #1
lakeside
Ontario and Quebec
B26, G11000 generator and a G1800
I was doing routine maintenance on my B26 on the weekend when I noticed the left hand FEL retraction hydraulic line had some damage to the outer rubber layer near the connector on the cylinder end. Nothing is leaking and the wire braid seems intact.
The tractor only has 365 hours on it but should I go ahead and replace the line, and maybe the other side as well or just leave it till it starts leaking?
Are the original Kubota hoses good quality or should I go with a better replacement hose for the few more $$ it would cost? :confused2:
/ B26 Hydraulic line damage #2
If it's not gonna be aiming at you when it springs a leak, I'd leave it. It may last years before its a problem. When you replace it , make sure you get a double braid hose.
/ B26 Hydraulic line damage #3
If the braid has not been compromised, tape it up with electrical tape or other to protect the wire braid from water/corrosion entering in between....
The outer cover is just protection for the braid........
(4) 17in. Honda Rims (A65640)
(4) 17in. Honda...
Ford Truck Tire and Rim (A65640)
Ford Truck Tire...
2019 Cadillac Sayers and Scovill 70IN Limo w Only 7729 Miles (A63689)
2019 Cadillac...
2015 Kenworth T800 T/A Wet Kit Sleeper Cab Truck Tractor (A64194)
2015 Kenworth T800...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
GIYI Skid Steer Mount Stump Grinder  (A62679)
GIYI Skid Steer...
