B2550 snowblower help
   / B2550 snowblower help #1
Wayne64SS
Duanesburg, NY
'13 MX5100HST, '82 B7100HST
I just bought this B2550 snowblower and am fabbing it to fit my B7100HST. I'm really hoping someone here has an owners manual for it? I've got the brackets all set so the subframe is physically bolted to the tractor and I tossed the old 3pt hitch linkage setup to lift and lower it. I have hydraulic parts off an old single stage kubota I'm goign to fab up to fit. I have mounted the rotater handle mount and made a plate for the valve to bolt which is now welded to that mount. Here's a few pics. My other question is this blower came with a shaft to hook to the mid-pto but it has the quick connect style end and my tractor doesn't support quick connect it takes a pin. Has anyone ever run across that situation and if so what did you do to fix it?
In the picture the blower is chained in the up position because I don't currently have a way to lift it and I need the service bay back.
2019 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2019 FREIGHTLINER...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
Nissan Forklift (A55973)
Nissan Forklift...
2012 UTILITY REEFER TRAILER (A58018)
2012 UTILITY...
