B2410 Bi-speed ordered
/ B2410 Bi-speed ordered #1
KDL
West Virginia
B2410 Bi-speed
My B2410 with Bi-speed turn is in!!! It arrived at the dealer on Thursday and should be delivered in a few days. I got a 60" mid-mount mower, grasscatcher and a 6' adjustable rear blade. I'll also be needing a trailer does anyone have any recommendations for a good one? How about tandem vs. single axle with or without brakes? Also what would be a good price for a used 4' brush hog.
/ B2410 Bi-speed ordered #2
KDL,
I still searching for my tractor, working with freinds or rentals. I pull the trailer/tractor combo every weekend to our new lot. I tried this once with a single axle that came with the first rental. I now own a (used)tamdem axle, four brake 16' trailer and will not use anything else. The tamdem reduces swaying (still need to to keep trailer and reciever level) it also helps reduce tongue weight on the truck. I bought the trailer with single axle brakes and add the second set for my personnal insurance and to keep the wear off my daily driver(DMV also required this).
I would check the rules in state regarding trailers before purchase, here in Connecticut if the trailer is rated for 3000# gross you are required to have brakes over 5000# you two axles and 4 brakes.
Hope this helps
2002 MITSUBISHI FG40K FORKLIFT (A66091)
2002 MITSUBISHI...
1991 BRENNER TANK TRAILER (A67714)
1991 BRENNER TANK...
2024 Unused Schulte 5026 26ft. Batwing Hydraulic Rotary Brush Cutter Tractor Attachment (A66734)
2024 Unused...
2004 NiftyLift TM50 HGE 50ft Towable Articulating Boom Lift (A66734)
2004 NiftyLift...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
2000 FREIGHTLINER CENTURY CLASS DUMP TRUCK (INOPERABLE) (A67714)
2000 FREIGHTLINER...
