Knight9
Veteran Member
Hi all,
Hoping you can help me with a problem I've encountered. I bought a King Kutter rotary cutter yesterday. After setting it all up and attaching it to the 3PH of my B2410, I found I have very little clearance from the ground at full height. I could adjust the rear height with the top link, but the front of the cutter is only about 1 1/2 to 2 " off the ground at full lift. Sure doesn't seem right to me. The front was catching on the ground just driving around. I do have a mid mount mower kit on although the mower is off. Is it possible that the lift kit on the mower is restricting the height of the 3PH???
Any suggestions? Anyone else had an issue with the clearance??
Thanks for you assistance.
Kevin
Kevin
