B2400 wont re-start after turning off
   / B2400 wont re-start after turning off #1
wrollerl
Kubota B2400; Kubota L3400
Hi all, new to the forums. Forgive me if this question has been asked... I could not find it with the search feature.
Just picked up a used B2400HSD yesterday. I believe it's pre-'97 so must be a '95 or 96'. 1200 hours, super clean machine. Was owned by an elderly man that bought it new. Looks like all he did was use it as a big riding mower with the belly mower attachment.
Everything seems to work well. Starts right up with a "cold" engine. The problem is after running for a while if I cut it off, I can't get it to start back up until it cools down for a while. The starter seems to work fine, battery is charged, fuel line is turned on, engine was not overheated (according to gauge) when turned off, radiator is full of coolant, oil and fuel all good. Engine just puffs black smoke while trying to start. Any ideas where to start? Fuel cutoff solenoid? If so, how do I troubleshoot?
I'm not a mechanic by any means but I am trainable.
Thank you!
   / B2400 wont re-start after turning off #2
When you switch the ignition to engage the starter does the starter spin?
If the starter spins well then it could/is likely to be a fueling issue.
yeah, engine is turning over and pumping out black smoke like it really wants to start bad, but just wont quite get there
   / B2400 wont re-start after turning off #4
Sounds like the fuel cut off solenoid is sticking...
   / B2400 wont re-start after turning off #5
Black smoke means incomplete combustion. I'd check fuel lines and connections: thermal changes can affect such. Fingers crossed that the injection pump is OK (when they start acting up they can exhibit issues when warm).
2019 Dodge Durango SUV (A46684)
2019 Dodge Durango...
2 Air Cannons (A47371)
Massey Furgeson Plow Bottom (pair) (A49251)
Massey Furgeson...
Ford 631 2WD Tractor (A49251)
Ford 631 2WD...
2015 Kia Optima Sedan (A46684)
2015 Kia Optima...
2011 FORD F-250 (INOPERABLE) (A48992)
2011 FORD F-250...
