B2400 Snowblower questions
/ B2400 Snowblower questions #1
thumper477
kubota bx2360
I just accquired a used B2660 Kubota snowblower and a Curtis cab for my B2400 tractor.I think that some of the parts might be missing.Is there a bracket that goes under the tractor that attaches to the arms of the blower?Also,how do the lift hoses for the blower attach to the tractor hydraulics?I was told there should be a block on the right side of the tractor near the pedals that the lift hoses attach to.I do have the rest of the hydraulics that go inside the tractor cab.I got a water heater for the cab when I got the cab and blower.Where should the heater hoses attach to the tractor engine?Any help with this would be appreciated and pictures would be great.Thanks for the help.This web site has been the best source of Kubota info that I have found on the net.
/ B2400 Snowblower questions #2
Do you have a front end loader?
The tractor needs the full underframe mount that comes with the blower to work I believe and the hydraulic hoses operate from the front end loader control valve quick couplers.
I do not recall where the heater hoses tie into the engine coolant lines or whether they plumb into the engine blocks coolant gallery. there are pictures of the heater install here on the Kubota forum if I remember correctly.
You can always send art white or neil messick a private message for help.
UNUSED AGT 12EX-ATA MINI EXCAVATOR (A64281)
UNUSED AGT...
UNUSED WOLVERINE 6' FORK EXTENSIONS (A64281)
UNUSED WOLVERINE...
2015 Ram 1500 Pickup Truck (A61573)
2015 Ram 1500...
3pt 4' Disc Harrow (A64119)
3pt 4' Disc Harrow...
Case IH 950 Planter (A63688)
Case IH 950...
Pair of Assist Wheels (A64119)
Pair of Assist...
