B2400 hydraulic problems
/ B2400 hydraulic problems #1
B2400
Platinum Member
Western Illinois
2016 B2650 ROPS, 1998 B2400 (sold!)
I have a 1998 B2400 with 860hrs on it and suffering some trouble with the hydraulic system. I changed the fluid,filter and suction screen and it seemed a little better. everything works good when first started but after about half an hour the power steering and endloader start getting weak. I've also noticed that the fluid temp appears to be awfully high. When running endloader the control valve gets hot enough to be very uncomfortable to the touch and today with the loader disconnected and just mowing,the loader valve was so hot you couldn't touch it. Anyone have any ideas? Thanks for any and all responses!! (I have taken it to dealer but after three days they sent it back to me and said they were waiting to hear back from kubota and to go ahead and use it!?)
/ B2400 hydraulic problems #2
I am taking a stab at it, and its a big guess. I am in no way a hyraulics expert. Could there be too much fluid with the extra pressure causing excess heat? Just a thought so I thought I'd mention. Good Luck!
I don't think so, fluid level is at the top mark on dip stick which manual says is normal range. Thanks for reply!!
/ B2400 hydraulic problems #4
i have the same tractor 98 b2400, have not experienced that problem. wonder why the dealer could not find the problem? that seems kind of odd /forums/images/graemlins/confused.gif i wonder if u don't have a valve that is constantly releiving, that would cause loss of lift and create a lot of heat. but would think the dealer should have been able to find that. please let us know what u find out.
My faith has slipped with the dealer too. They picked it up monday night.. called tuesday afternoon said a Kubota rep was there and checked it out and suspected as you the relief valve was sticking. they said they would hook it up to some guages the next day(WED). Called Wed. and was told that they looked at it again and they would be putting the guages on it the next day(Thurs). Needless to say I got a little upset with my sales man and requested something to mow my yard with since my recent purchase was busy taking up space in there shop! Thursday night they brought my 2400 back and said they were waitng for a call from kubota and when they here back they would call,pick mine up and fix it. I hope it doesn't self destruct while waiting for this call!! Thanks for the reply!
/ B2400 hydraulic problems #6
B2400
A quick check, try moving the 3PH control so the arms move off full up. The full up adjustment may be out of adjustment causing the relief valve to be open all the time.
/ B2400 hydraulic problems #7
Well, does your tractor have SUDT or at least UDT? Does it have possibly contaminated fluid. Condensation--infrequent use?? Well, anyway, today I made a point of touching my loader valve while mowing--YEP--as expected--it is very hot. Did I say it is HOT /forums/images/graemlins/shocked.gif? I am not sure what is wrong with your unit--was it bought used?--but I suspect bypassing fluid somewhere. J
/ B2400 hydraulic problems #8
Did The dealer tell you what he kind of pressure readings he got? Does the engine seem like its loaded down when you run it (wondering if its an hst problem, don't know if your unit is hst)? Do you hear anything odd (a high pitched whistle or whatever) when you run it? How long has it been doing this?
Sounds like a flow restriction like others have mentioned, causing alot of friction and heat. I wonder if its in the fel valve, power steering, or a remote valve, if you have remotes.
Hope this helps. Good luck, I hope you find the problem.
DaveL
The Manual says Super UDT($$$), so thats what I put in it. The three point was all the way down in the float position so I don't believe thats the problem. The call from Kubota came thru and they seem to think that the power steering is in bypass,But I haven't heard the noise ( high pitched squeal) from the bypass. Engine doesn't seem to be under constant load so I'm back to square one....Lost!!! It goes back to the dealership tommorow, Kubota told them of some other tests to run to isolate the problem. I'll keep everyone posted on the results. Thanks to all for your responses and concern. I've gotten more ideas and answers from you than the dealership
Howdy All!! I just got off the phone with the dealership and I'm not too happy. Mechanic says that all pressures were in spec and oil temp holds a steady 180( guess thats pretty hot to the touch!) but well within kubota's recommended range. Looks like I have to live with poor power steering and weak endloader performance. I do have a friend who is knowledgeable about hydraulics and am going to consult with him. Also checked price for new pump and that's Approx. $450,but if pressure is correct this probably isn't the answer. With hydraulics I believe pressure is power and volume is speed. Enough whining for know , if any progress is made I'll update via this thread. Thanks everyone!!
/ B2400 hydraulic problems #11
My 2400 just spent 40 min spinning the 5 ft rear mower and these are my observations upon completion: cast iron loader valve body is uncomfortable to the calloused fingers and the steel angle fitting from the hose to valve body is pretty close to painful on the backs of the fingers. Oil cooler tubing in front of the radiator is hot enough to prevent more than a quick grasp. Checking the radiator screen at the same time. I'd say your temps are in the neighborhood of what I'm seeing. This was hilly around a couple of dozen trees mowing at a good clip (seat belt on for a reason) type mowing that made these temps. How heavy is your counter weight and what is the air pressure in the front tires? My steering barely functions at loader capacity (700# if memory serves me correctly) with 400# on the 3PH with loaded rears. I use this as my warning that the tractor is at its max and shouldn't be tooling around corners anyways. 4WD winding up from soft tires on hard surfaces doesn't help either./forums/images/graemlins/smile.gif SteveV
When I last used the endloader I had a 420lb brushcutter on the back for counter weight. Bucket empty it has virtually no power steering at low speeds. This is especially true if rpm's are much below 2000. I seriously doubt that the endloader will pick up 300lbs, it stalls out trying to pick up 1/2 bucket of fairly dry dirt. Let's not even talk about gravel!! Oil temps are probably ok as my wife says I'm a real wimp about heat related things ( dishwater......!) I'm planning to borrow a friends infrared thermal gun and check the temps with it. Same friend is sharp with mechanical/hydraulics so I'm going to enlist his brain power with this also. Hoped it wouldn't have come to this as I thought the dealership where I got it would be more helpful,but they continue to insist that everything is within specs so there's nothing they can do. Pretty bad when salesman and service manager both say it's not right but I'll just have to live with it. Obviously I've spent my last dime there.
/ B2400 hydraulic problems #13
There must be something wrong with the power steering cylinder. It is bypassing or leaking or something. I would insist it be fixed so that it performs exactly like the new one on the lot--does it??? My 2410 steering does not fade out when hot and yes the fluid lines and FEL block get hot. Sometimes when I put a large and rapid steering imput into the wheel there is a momentary--very momentary and very slight increase in effort--almost like a pulse. It has been this way since new. It ain't no Miata but it steers with one finger. J
/ B2400 hydraulic problems #14
The FEL capacity issue is pretty cut and dry. Either you have rated pressure or you don't and the dealer should have had a pressure gage to determine this. 3PH capacity is also determined by this same pressure. The sizes of the cylinders don't change by themselves. I'm not sure if there's a separate pump for the power steering or not. Indirectly, pressure can be calculated from lifting known weight in the bucket (like your cutter). Rated speed for rated capacity! /forums/images/graemlins/smile.gif SteveV
Hi everyone! I got my 2400 back from the dealership friday night and was told all pressures were within specs( just shy of 2000psi) and oil temps were consistent 180 and thats just the way the tractor was going to be. Needless to say I was not too happy. Took it out that night just to move some gravel and behold... endloader seemed to have good power! I was actually able to pick the back of the unit up off the ground with the loader buried in a pile of rock!! Is it possible they found a mistake( such as power beyond plumbed backwards?) and just didn't want to say? I'll probably never know. Either way we moved about 15 ton of dirt and 3 ton of rock over the weekend with no problems other than power steering still not as strong as I'd like,but it too appeared to be better. I love small miracles!!! Thanks to everyone for your suggestions and tips.
Mike Allen
Used Landpride GR1525 Stump Grinder
Used Landpride...
(50) UNUSED 3'x8' CORRUGATED METAL SHEETS (A64281)
(50) UNUSED 3'x8'...
2012 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2012 Chevrolet...
2001 Freightliner FL70 Day Cab Truck, VIN # 1FUBBUAK21HJ24793 (A65563)
2001 Freightliner...
Caterpillar D5B Dozer Parts and Service Manuals (A63117)
Caterpillar D5B...
New 5/16" G80 Double Chain Sling (A62679)
New 5/16" G80...
