B2400 Blows Smoke When Starting Implements
   / B2400 Blows Smoke When Starting Implements #1
BradB
Central Eastern Pa
Kubota B2400
I have a B2400 that is great. Always starts, runs well, easily pulls the FL1271 tiller but when starting the mower or the tiller for example it blows a little black smoke and then it's on it's way.
Any insight on the cause and should I be concerned? I've noticed it maybe 100 hours ago or so, has 1680 at this point in time. I don't notice any loss of power, it still pulls the tiller as it ever did, even when all the way down.
   / B2400 Blows Smoke When Starting Implements #2
Hmmm:confused: Sounds like a diesel:D I would not worry.:thumbsup:
   / B2400 Blows Smoke When Starting Implements #3
totally normal.
you have the engine set a certain speed, load is applied, governor is trying to maintain set speed, allows a little more fuel, then it is leaned out a bit as speed picks up. ( black smoke is unburned fuel )
My B2400 does the same thing, 1205hrs
   / B2400 Blows Smoke When Starting Implements #4
Yes, I agree this is normal.
   / B2400 Blows Smoke When Starting Implements #5
Yep, normal for all of mine; amount depends on the load.
Wow, that's awesome. Thank you all, that is good to know. I knew the black smoke was not oil so I wasn't real concerned at first, but it's up there in hours and didn't want to do damage. I love that **** tractor. You're sharing of your experience and knowledge is greatly appreciated.:thumbsup:
   / B2400 Blows Smoke When Starting Implements #7
1700hrs? Just getting broke in!!
   / B2400 Blows Smoke When Starting Implements #8
Yes, it is normal and not an issue unless it
has been a long time since you changed
the inner and outer air filters.
2013 GENIE S-85 TELESCOPIC MANLIFT (A51242)
2013 GENIE S-85...
UNUSED FUTURE SKID STEER 4IN1 COMBO BUCKET (A51244)
UNUSED FUTURE SKID...
2013 VERMEER RTX1250 RIDE ON TRACTOR (A51242)
2013 VERMEER...
UNUSED FUTURE MINI EXCAVATOR HYD 18" AUGER (A51244)
UNUSED FUTURE MINI...
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
TOW BEHIND FINISH MOWER (A50324)
TOW BEHIND FINISH...
