B2400 API oil spec in the ownes manual
   / B2400 API oil spec in the ownes manual #1
Racer11
Mc Louth, Kansas
Kubota 2400 jd 4240
Time to change my oil and I noticed that my owners manual says to use API CC/CD rated oil. Mobil 1 now offers zero rated oil 0-20 and 0-30,,,that sounds good for winter start ups in my unheated barn.
I would like some in put to using 0-30 Mobil 1 in the engine rather than a diesel rated oil,,something the owners manual does not recommend.
   / B2400 API oil spec in the ownes manual #2
CC/CD is diesel rated oil. See if Mobil 1 makes a 10W30 CC/CD Rated oil and if so use that year round.
   / B2400 API oil spec in the ownes manual #3
Kubota's manuals are woefully outdated on oil specs.
The current diesel spec is CJ-4,superceeding CC/CD.
Kubota factory fill is 10W30 conventional oil.
This would serve you well in Kansas,Shell Rotella or Kubota 10W30 are easy to find.
If you desire a lower viscosity synthetic oil for easier starts,5W40 CJ-4 oils for diesels are plenitful.
Shell Rotella,Mobil Delvac,etc.Any would be fine.
The Mobil 1 synthetics you mentioned are gas engine oils and don't have the capability to handle the soot load diesel engines require.
Good Luck!
Number two,,,,,Thank you sir, that answers what I needed to know. The Shell Rotella 10-30 will be my fill this weekend.
   / B2400 API oil spec in the ownes manual #5
Also, all CI-4, CI-4+, and CJ-4 oils are backward compatible. They can be used in CC, CD, CF, designed engines with no problem.
2016 CATERPILLAR D5K2 XL CRAWLER DOZER (A52706)
2016 CATERPILLAR...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2016 Ford F-750 Flatbed Truck (A52377)
2016 Ford F-750...
VERMEER 605F ROUND HAY BALER (A51247)
VERMEER 605F ROUND...
2014 HINO 338 26FT CDL REQUIRED BOX TRUCK (A54607)
2014 HINO 338 26FT...
2020 Kia Soul SUV (A52377)
2020 Kia Soul SUV...
