Mowing B2320 with 60" deck - problems leveling
   / B2320 with 60" deck - problems leveling #1
dbznwaild
Medina, NY
B2320
Hello - I have a B2320 with a 60" MMM and cannot seem to get the deck level on all four corners. I've adjusted the 2 leveling brackets at the rear of the deck as well as the turn buckle bracket in the front and no matter what I do the right front corner is 1/2" lower than the rest of the deck which has caused that particular anti-scalping wheel to wear flat - even with the required gap between the wheel and the ground when parked on a level surface. I've gone back to the factory measurements on all the brackets (for a tractor with industrial tires) and I still have the same issue. Looking at the design of the deck I can see were the back brackets obviously adjust the back of the deck left and right, and I can see how the front bracket may adjust the level of the deck from front to back, but how do you adjust the level across the front? Is it possible? Thanks!
   / B2320 with 60" deck - problems leveling #2
I'd have to get the MMM manual, even if I was asking the same question. When mine was new , I must have spent 2-3 hours getting it adjusted using the manual directions. The answer must be in there, but it seemed difficult to me as I recall. I cut a handy plastic ruler to take the measurements in mm. I've never gone back to check it again. The mowing result looks okay to me. Check that your tire inflation is proper.
Cheers,
Mike
2015 Ford Taurus Sedan (A56859)
2015 Ford Taurus...
1994 Club Car Electric Cart (A56859)
1994 Club Car...
New/Unused 14ft Bi Parting Gate (A57454)
New/Unused 14ft Bi...
12ft 9in Altec Service Bed (A57453)
12ft 9in Altec...
PowerBoss Admiral Plus 38C Ride-On Floor Scrubber/Sweeper (A59228)
PowerBoss Admiral...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
