B2320 temperature gauge not working?
   / B2320 temperature gauge not working? #1
johnhenry222
Buckhannon WVa..
Kubota B2320
I took my B2320 to dealer for temperature gauge not working right The dealer had it for two weeks and said it was in the ground.I brought tractor home and the temperature gauge still won't work.The gauge goes up to the little black area and stops.There is a white wire going to the sending unit but where is the ground wire?
   / B2320 temperature gauge not working? #2
So you are getting a little movement in the gauge when the engine warms up, but not very much? It's apparently typical for Kub's to indicate low on the temp gauge until you really make them work hard. Both of mine are like that, at least. It's only when doing something like heavy brush mowing on a 90+ degree day that the temp goes up higher than about 1/3 scale.
   / B2320 temperature gauge not working? #3
I know my B2630 tempature barely makes it out of the black. Agree with previous post that they seem to run on the cool side
   / B2320 temperature gauge not working? #4
Mine used to not go to mid scale until I replaced the thermostat.
DOOSAN G25KW GENERATOR (A55745)
DOOSAN G25KW...
Heavy Duty 2 Post Car Lift (A57454)
Heavy Duty 2 Post...
2021 KENWORTH T680 TANDEM AXLE SLEEPER (A59575)
2021 KENWORTH T680...
2020 Deere 750K LGP (A53317)
2020 Deere 750K...
2007 Honda CR-V SUV (A56859)
2007 Honda CR-V...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
