B2150 strange noise - looking for advice for what to look at
   / B2150 strange noise - looking for advice for what to look at #1
moeh1
Upstate NY
B2150DT / B2150 Hydro / Hinomoto JF-1
My B2150 gear tractor just started “banging” when driving forward like once a second when advancing slowly. It doesn’t make noise in reverse. Doesn’t matter if the clutch is pushed in. It does it all 3 ranges and with our without 4wd engaged. It sounds like it is coming from the tunnel between clutch and rear end. Any ideas are appreciated!
   / B2150 strange noise - looking for advice for what to look at #2
Check universal joints on drive shaft
Can you point me a little better where?
   / B2150 strange noise - looking for advice for what to look at #4
I sold my 2150 and I remember the new owner had this problem develop later. It was the front driveshaft universal.
:) You guys nailed it! Broken universal joint. Easy fix. Thanks.
Tractor is all back together. Kubota u joint is $60, similar one from the u joint store is $20 (20 x 55mm). I’m still smiling though, its running again.
UNUSED FUTURE 40" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 40"...
2015 Kubota KX91-3S2 Mini Excavator (A55973)
2015 Kubota...
2016 Toro Workman HDX-D Utility Cart (A55787)
2016 Toro Workman...
IRanch Dump Hopper (A55851)
IRanch Dump Hopper...
2019 CATERPILLAR 259D SKID STEER (A52707)
2019 CATERPILLAR...
UNUSED FUTURE MINI SKID STEER MOUNTING PLATE (A57193)
UNUSED FUTURE MINI...
