B2150 strange noise - looking for advice for what to look at
   / B2150 strange noise - looking for advice for what to look at #1
moeh1
Gold Member
Upstate NY
B2150DT / B2150 Hydro / Hinomoto JF-1
My B2150 gear tractor just started “banging” when driving forward like once a second when advancing slowly. It doesn’t make noise in reverse. Doesn’t matter if the clutch is pushed in. It does it all 3 ranges and with our without 4wd engaged. It sounds like it is coming from the tunnel between clutch and rear end. Any ideas are appreciated!
   / B2150 strange noise - looking for advice for what to look at #2
Check universal joints on drive shaft
Can you point me a little better where?
Thanks
   / B2150 strange noise - looking for advice for what to look at #4
I sold my 2150 and I remember the new owner had this problem develop later. It was the front driveshaft universal.
:) You guys nailed it! Broken universal joint. Easy fix. Thanks.
Tractor is all back together. Kubota u joint is $60, similar one from the u joint store is $20 (20 x 55mm). I’m still smiling though, its running again.
2018 Chevrolet Tahoe SUV (A55853)
2018 Chevrolet...
2023 Deere 318G (A53317)
2023 Deere 318G...
Gorman Rupp T4A3-B 4in Centrifugal Dewatering Pump (A55851)
Gorman Rupp T4A3-B...
2014 FORREST RIVER SALEM TRAVEL TRAILER (A55745)
2014 FORREST RIVER...
UNUSED SDLANCH HYD MINI THUMB CLAP7P (A57193)
UNUSED SDLANCH HYD...
Bush Hog 7007 Grader Blade (A53317)
Bush Hog 7007...
