B2150 loose steering
   / B2150 loose steering #1
kcarl
NC, NW Piedmont area
B2150
While torn down to replace the axle housing on my 2150, I decided to work on the loose steering. I replaced the worn rubber bushing on the steering wheel shaft, but still have a lot of left to right play before the pitman arm moves. There is a large adjustment screw with a lock nut on the steering shaft, but I think that is a relief valve screw/spring/poppet, which I'm assuming I shouldn't mess with. Does anyone know if there is an adjustment screw to tighten things up?
Thanks,
Kcarl
   / B2150 loose steering #2
If the nut and set screw are on the side of the steering gearbox that is where you make your adjustment. Loosen the locknut and turn the screw untill it botoms out and back it off 1/4 turn and retighten the locknut. This should put you close.
Bill
the diagram indicates the nut and screw adjust a relief valve, which is a section above the gearbox.
thanks,
kcarl
2017 Ford E450 Super Duty 20 Passenger Bus (A47384)
2017 Ford E450...
2006 John Deere HPX Gator 4x4 Utility Cart (A50322)
2006 John Deere...
METAL BOX (A51243)
METAL BOX (A51243)
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
2018 CATERPILLAR 299D2 SKID STEER (A51242)
2018 CATERPILLAR...
2011 Ford F-250 Omaha Service Truck (A50323)
2011 Ford F-250...
