Tires B2150 Front Turf Tires & Split Rims
   / B2150 Front Turf Tires & Split Rims #1
aquetrac
Riverhead, NY
Kubota B2150, Kubota B21, Kubota B1750, Kubota BX23
I recently picked up a B2150 HSD with turf tires. The fronts are 24X8.5-12 and I had a leaking stem. I brought it to my local tire store to get the stem replaced. This rim is the type that has bolts holding the 2 halfs together. They told me the rim had to be seperated to get a new stem in. When they put it back together, it was leaking between the rim sections and they said I needad a tube which they did not have.
How are these rim sections sealed? I took them apart myself and did not see any type of gasket or sealant. Also I know I need to repace these front tires as they are badly cracked. I've looked around but they are pretty scarce. Amyone know of a supplier for these, they are Bridgestone Pillow Diameter, 24X8.5-12?
Thanks for any ideas!
   / B2150 Front Turf Tires & Split Rims #2
Mine has the same tires, and I need to replace them, but can't find any locally. The Bridgestone part number is 359-750.
Good luck.
   / B2150 Front Turf Tires & Split Rims #3
You should have a thick black rubber gasket between the 2 halves. It is alot of fun getting this and the tube back in and bolted together, I recently had to replace tube in mine. Kubota dealer for the gasket, but it probably isn't needed if you go the tube route.
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A52748)
2017 KINZE...
2018 Maserati Ghibli Sedan (A50324)
2018 Maserati...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
2018 JLG 1932R 19FT Electric Scissor Lift (A50322)
2018 JLG 1932R...
2013 Chevrolet Cruze LS Sedan (A50324)
2013 Chevrolet...
Pitts Tri-Axle RGN Lowboy Equipment Trailer (A50323)
Pitts Tri-Axle RGN...
