Tires B2150 Front Turf Tires & Split Rims
   / B2150 Front Turf Tires & Split Rims #1
aquetrac
Riverhead, NY
Kubota B2150, Kubota B21, Kubota B1750, Kubota BX23
I recently picked up a B2150 HSD with turf tires. The fronts are 24X8.5-12 and I had a leaking stem. I brought it to my local tire store to get the stem replaced. This rim is the type that has bolts holding the 2 halfs together. They told me the rim had to be seperated to get a new stem in. When they put it back together, it was leaking between the rim sections and they said I needad a tube which they did not have.
How are these rim sections sealed? I took them apart myself and did not see any type of gasket or sealant. Also I know I need to repace these front tires as they are badly cracked. I've looked around but they are pretty scarce. Amyone know of a supplier for these, they are Bridgestone Pillow Diameter, 24X8.5-12?
Thanks for any ideas!
   / B2150 Front Turf Tires & Split Rims #2
Mine has the same tires, and I need to replace them, but can't find any locally. The Bridgestone part number is 359-750.
Good luck.
   / B2150 Front Turf Tires & Split Rims #3
You should have a thick black rubber gasket between the 2 halves. It is alot of fun getting this and the tube back in and bolted together, I recently had to replace tube in mine. Kubota dealer for the gasket, but it probably isn't needed if you go the tube route.
2015 Toro Z Master Professional 64in Zero Turn Commercial Mower (A50322)
2015 Toro Z Master...
1999 Freightliner Service Truck (A50514)
1999 Freightliner...
2013 Ford F-550 4x4 Horton Ambulance (A50323)
2013 Ford F-550...
Wolverine Quick Attach Screening Bucket (A50514)
Wolverine Quick...
2022 Robex 55-9A Midi Excavator (RIDE AND DRIVE) (LIKE NEW) (A50774)
2022 Robex 55-9A...
2011 Nissan Titan SV 4x4 Crew Cab Pickup Truck (A50323)
2011 Nissan Titan...
