B2150 Air Filter(s) ?
/ B2150 Air Filter(s) ? #1
TimP
Platinum Member
Kingsville, MD
B3000HSDCC
Hi All.
I have a B2150 and was going to change/clean my air filter.
I have read that some Kubota models have TWO air filters. A primary(outer) and a secondary/safety (inner) air filter.
Does anyone know if my B2150 has one, or two, air filters?
Thanks !
/ B2150 Air Filter(s) ? #2
I had a B1750(same series)and only had one air filter.
I would think yours is the same filter.
Good Luck!
Thanks number two.
I don't recall ever reading about a second filter, and don't think I saw one in the parts manual either.
So I will assume it is just one filter.
Thanks again.
/ B2150 Air Filter(s) ? #4
I have 2 B2150's. Located an old filter. Just one cylindrical body with plate on one end for wing nut attachment to the metal cone that serves as air intake. I have a "Workshop Manual" for the B1550, 1750, 2150 series. Only one small picture there with a note on the air filter and it shows a single stage filter. It does ring a bell that there may be a dual inner and outer filter version. It's not like one feeds the other through tubing or something. If you have two, there would likely be an inner cylinder and an outer cylinder of filter material covered with steel mesh. Just take the filter housing apart as you normally would for inspection/replacement and see what you have.
JWR,
Thanks for the info. I looked at my filter and it appears to be just one large cylinder. Not any double layer or anything.
I thin it's safe to assume I only have a single filter and should be good just replacing what I see.
Thanks again.
Regards.
/ B2150 Air Filter(s) ? #6
Yes. I expect you'll have to go to a dealer for that filter. Not all that common and I doubt you could find it in a parts store, though these days you can find darn near anything on the web.
Thanks. I'll give my local Kubota dealer a call.
/ B2150 Air Filter(s) ? #8
Most of the newer stuff is designed and made by Donaldson. Not sure about yours but my L3940 inner and outer air are identical to the Exmark zero turn mower I just bought but half the price from Exmark or Kohler.
Donaldson P53562
eCatalog - P535362
Cross References
AMERICAN PARTS 94496 BALDWIN PA3476 BIG A 94496 BOBCAT-MELROE 6682494 CARQUEST 88496 CASE-IH CNH GLOBAL 200045A COOPERS AEM2634 FLEETGUARD AF4939 FLEETRITE AFR84939 FRAM CA7088
Kubota prices are stupid.
Regards, Fred
Regards, Fred
Hi The Fred Thanks for that info.
I agree about the Kubota prices. They are pretty high up on the scale.
Regards
Or you could just look and see.
Thanks RickB.
I did look, but did not see anything apparent.
I wanted to make sure that there wasn't some sort of secondary filter further downstream that I was not aware of....
Regards.
/ B2150 Air Filter(s) ? #12
Donaldson P53562
eCatalog - P535362
Cross References
Regards, Fred
would you post your kubota oem part #'s for your air filters?
