B21 Will Not Start
/ B21 Will Not Start #1
Whitey
Slippery Rock, Pennsylvania
Kabota B21 TLB
OK..........I have a 2005 B21 with less than 400 hours that spends most of it's life cooped up in the garage. Over the last year I have had difficulty starting this bugger and now I am just jumping the starter with a screw driver. I have been through and cleaned the ground cable, checked the battery strength and jumped out the two different safeties with no avail. I just read a post about adding a JD part to the ignition and this solves the problem.
Can anyone confirm this? Has anyone actually suffered the same problem as I found a different solutution?
Thanks.
/ B21 Will Not Start #2
You need to check and see if you are getting voltage to the starter when you turn the key if not check the safety switches (twice). If your getting less than 12v when you move to the start key they you may need a extra solenoid, but your start should not need one.
/ B21 Will Not Start #3
There are three safety switches.
1) Clutch pedal
2) PTO gear shift lever
3) Range gear shift lever (serial number below 60970)
4) HST pedal (serial number above 60971)
Log Chain (A65640)
Log Chain (A65640)
2017 Ford Explorer AWD SUV (A64557)
2017 Ford Explorer...
121A (A63745)
121A (A63745)
Bobcat Pallet Forks (A64127)
Bobcat Pallet...
2022 CATERPILLAR 289D3 SKID STEER (A64279)
2022 CATERPILLAR...
Landhonor HPF-11-3000G, 48" Heavy Duty Forks (A62679)
Landhonor...
