3-Point Hitch B21 top link and lift arm questions
   / B21 top link and lift arm questions #1
Leozepolusa
Austin, TX
Kubota B21 & L47 TLB
Hello,
I am trying to use my B21's three point hitch for the first time. I bought an after market top link from Tractor Supply that I tried to use this morning when I noticed the space between the top link brackets on my B21 is about 1/8" narrower than the top link's ball joint. Needless to say, it dosen't fit. Has anyone experienced and solved this problem? Should I just shave the top link ball joint down to size?
I also noticed the Kubota original lifting rods have 3/4" pins for the lower lift arm connection, but the original lower lift arms have 1/2" holes for those same pins. Is it normal to have 1/4" of play at this connection?
Thanks for any help.
   / B21 top link and lift arm questions #2
No, this is not normal. BTW, is your B21 CAT 1 or 0? My bet is 0 and you are using CAT1 hardware.
It's all category 1.
   / B21 top link and lift arm questions #4
This is pretty common on some Kubotas. Basically all you have to do is gring 1/16" off both edges of the top link to make it fit.
   / B21 top link and lift arm questions #5
If you are interested in getting the official Kubota parts, there is a 3 point hitch kit for the B26 that will fit the B21 and costs about half the price of ordering the B21 parts individually. The 3 point kits part number is B3941.
I'm pretty sure I figured out the problem. Apparently the guy I bought the tractor from must have drilled out the Kubota lift rod forks from 1/2 inch out to 3/4" to work with after market lift arms he sold with the tractor. When I bought the Kubota OEM lift arms the mis-match surfaced. I guess I have a choice to make; weld bushings in the forks, drill out the OEM lift arms to 3/4", or do nothing and not worry about the 1/4" play at the lift rod pins.
Thanks for the responses.
2018 Ford Explorer AWD SUV (A55853)
2018 Ford Explorer...
2013 CAT 950K WHEEL LOADER (A53843)
2013 CAT 950K...
2017 VOLVO VNL64T670 TANDEM AXLE SLEEPER (A57880)
2017 VOLVO...
2019 BOBCAT T450 SKID STEER (A52707)
2019 BOBCAT T450...
2022 Ford Escape S AWD SUV (A54815)
2022 Ford Escape S...
gravely riding mower (A53424)
gravely riding...
