B21 TLB what are it's pto limitations?
   / B21 TLB what are it's pto limitations? #1
Agentiron
Northwest Indiana
B21 TLB what are it\'s pto limitations?
I am thinking of a B21 for landscape purposes but will also want to use some 3 point attachments. I will likely want to use a bushhog, boxblade, and hopefully a Harley Rake. I fear the latter may exceed the ability of the unit.
Anyone with experience with the B21, could you share your thoughts with me?
Thanks
   / B21 TLB what are it's pto limitations? #2
Re: B21 TLB what are it\'s pto limitations?
I have a B21 TLB with the hoe off I use a 4 foot brush hog,5 foot finish mower,5 ft. box blade and an 8ft york rake with tires. You will never get a harley rake powered by a B21 cause it is too heavy uses too much power and you will need a hydraulic valve installed on the tractor! /forums/images/graemlins/smile.gif
Thanks for the reply Biged.
Are you happy with the unit, or do you regret not having more power? Do you load any small dump trucks with it, and if you do does it have sufficient elevation and reach to do the job? Do you feel this unit could manage digging an occasional basement for some home additions?
Thanks
   / B21 TLB what are it's pto limitations? #4
Sure you dig foundations down to about 7 ft. I wish I had more power so I could use my 6 ft brush hog 4 ft is kinda slow. I am looking for a JD 5 sickle bar mower. It is not recommended but should work cause it is not 3 Ph. Very happy with this machine cause it uses less than 1gallon per hour @ 2000 rpm My IHC 460 uses 5 per hour /forums/images/graemlins/smile.gif
2016 CATERPILLAR 262D WHEELED SKID STEER (A51242)
2016 CATERPILLAR...
2018 Toro Groundsmaster 7210 Model 30695 72in Zero Turn Mower (A50322)
2018 Toro...
2022 CATERPILLAR CS54B SMOOTH DRUM ROLLER (A51242)
2022 CATERPILLAR...
2017 Ford F-250 4x4 Knapheide Service Truck (A50323)
2017 Ford F-250...
2021 CATERPILLAR 259D3 SKID STEER (A51242)
2021 CATERPILLAR...
2023 Bobcat T770 Skidloader (RIDE AND DRIVE) (LIKE NEW) (A50774)
2023 Bobcat T770...
