B21 leaking hydro fluid at the rear axle right side.
   / B21 leaking hydro fluid at the rear axle right side. #1
MLS2011
Kubota B21
how much trouble is this to change. Dealer said 700.00
   / B21 leaking hydro fluid at the rear axle right side. #2
The whole axle has to be reomoved from the tractor and disassebled.
   / B21 leaking hydro fluid at the rear axle right side. #3
is it leaking from the axle trumpet where it meets the center housing.. or the hub at the mouth of the trumpet?
soundguy
leaking where the axle shaft first enters the housing as looking from the back. In other words where the shaft is no longer visable. thanks
   / B21 leaking hydro fluid at the rear axle right side. #5
How old is your B21, how many hours?
Is this a "drip a minute" or "drip an hour" leak?
No experience with this, but just curious....
Pete
2017 KINZE KNOTCHED SINGLE DISK FERTILIZER OPENER FOR 3000/3500 SERIES PLANTERS (6 ROWS) (A53473)
2017 KINZE...
2018 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
2025 Wolverine EX-66-84L Pallet Fork Extensions (A53117)
2025 Wolverine...
2018 FORD F-150 (A53843)
2018 FORD F-150...
1992 Peterbilt 377 Sleeper Cab (A53473)
1992 Peterbilt 377...
2016 Freightliner Gradall D152 Truck Mounted Excav (A53117)
2016 Freightliner...
